What are differences in default contact settings for Contact Element Keyoptions and Real Constant Values between WB Mechanical and MAPDL environments ?
March 17, 2023 at 9:00 am
FAQ
ParticipantBelow exact help manual link shows the differences in Keyoption and Real Constant Values between WB Mechanical and MADPL Online help manual link: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/ans_ctec/Hlp_ctec_realkey.html?q= Local Help manual link : help/ans_ctec/Hlp_ctec_realkey.html#strconst10jla072099 (open Ansys help manual then Shift+Ctrl+D to paste this link) Table 3.1: Summary of Real Constant Defaults in Different Environments Table 3.3: Summary of KEYOPT Defaults in Different Environments
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
