We use NFS mounts, and when I try to install 18.2 and 19.0 using the -silent options, I get the following error: >>>—> Error: Install Directory Error: The installation directory path is too long. Current Maximum Path Length: 100 A path greater than the current maximum path length could cause problems when running the product. Please choose a shorter path. How can I disable the 100 character length limit for the path?
- >>—> Error: Install Directory Error: The installation directory path is too long. Current Maximum Path Length: 100 A path greater than the current maximum path length could cause problems when running the product. Please choose a shorter path.
How can I disable the 100 character length limit for the path?" target="_blank" rel="nofollow" title="LinkedIn"> - >>—> Error: Install Directory Error: The installation directory path is too long. Current Maximum Path Length: 100 A path greater than the current maximum path length could cause problems when running the product. Please choose a shorter path.
How can I disable the 100 character length limit for the path?" target="_blank" rel="nofollow" title="whatsapp"> - >>—> Error: Install Directory Error: The installation directory path is too long. Current Maximum Path Length: 100 A path greater than the current maximum path length could cause problems when running the product. Please choose a shorter path.
How can I disable the 100 character length limit for the path?" target="_blank" rel="nofollow" title="reddit"> - >>—> Error: Install Directory Error: The installation directory path is too long. Current Maximum Path Length: 100 A path greater than the current maximum path length could cause problems when running the product. Please choose a shorter path.
How can I disable the 100 character length limit for the path?" target="_blank" rel="nofollow" title="facebook">
April 5, 2023 at 2:32 pm
FAQParticipantWe actually set the path limit to 100 characters for all installations because some ANSYS applications can’t handle being buried in a directory structure that is too deep. You will need to choose to install to a location that does not contain so many characters.
