June 6, 2022 at 8:33 am
FAQParticipant1) if the geometry is moving or getting deformed or any boundary condition type is getting changed, everytime the view factors need to be re-computed
2) in case of moving domains/solids, with dynamic mesh motion or sliding mesh motion, the s2s view factors should be computed frequently to account for the change in geometries
3) however, while using MRF, the view factors needn’t be up[dated as only the reference is moving, and not the actual geometry
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
