August 25, 2023 at 12:16 pm
SolutionParticipantThis video is from an internal meeting that highlights the following relevant knowledge material articles. 2049044: Fluent Versions before 14.0 fail to checkout license with ANSYS CFD Premium 2049004: Unable to checkout licenses from WAN 2049003: Error: Refining meshes, reconciling multiregion mesh component IDs and overlaps 2049007: Using another MPI method for Fluent runs inside ANSYS Workbench 463606: Error: “Can’t read env(Ansys_appdata_dir) no such variable” from ANSYS Product Launcher 2048864: How to create a whitelist for ANSYS License Servers This video and the associated presentation are made available to our customers in hopes that you will find the technical content useful. Please refer to the attachments to access the video and the related presentation.
1. 2049207.pdf
2. 2049207_NewSolutions12.mp4
