Velocity Magnitude contours show some spots outside plane surface after using transform functionality.
Tagged: 19, fluent, fluent-post-processing, fluid-dynamics
April 5, 2023 at 2:32 pm
FAQParticipantThis is bug and reported in R19.0. You may want to use different method to create isosurface.
- Skewness in ANSYS Meshing
