June 5, 2023 at 7:05 am
FAQParticipantIn case a variable Turbulent Prandtl Number is defined via a CEL Expression with a temperature dependent quantity, the following error message might occur: Error in subroutine GETCORE: There is a circularity in recursive calls to GETVAR. A variable depends upon itself! Oper = What = Temperature Where = Fluid When = TIME-0 Action = RETURN. Stopping GETVAR originally called by subroutine DEF_DIFTRBC” The solution is to append the Expression Language Operator linlin to the quantities which depend on temperature, i.e. Dynamic Viscosity.linlin The linlin operator ensure that the values at the integration points get interpolated from the nodal values, instead of evaluating the temperature at the integration points from Enthalpy. Example: EXPRESSIONS: TuPr = Dynamic Viscosity.linlin * Specific Heat Capacity at Constant Pressure.linlin / Thermal Conductivity.linlin END
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
