June 3, 2022 at 1:43 pm
Watch & LearnParticipantMaterial Designer is an ANSYS tool for the homogenization of microstructures, enabling you to model and analyze composite materials at a microscale to obtain homogeneous properties. Using a woven fabric draped over a dome-shaped structure as an example, this video demonstrates how to use Material Designer along with ANSYS Composite PrepPost to determine variable material properties as a function of shear angle.
- Introduction to ANSYS Material Designer
- ANSYS ACP: Lay-up Mapping of a Composite Spring
- Ply Staggering with ACP – ANSYS Composite PrepPost
- Ansys Material Designer – User Defined RVEs (Representative Volume Elements)
- Variable Material Properties Calculated in Material Designer
- ANSYS Material Designer: Calculating Variable Material Properties
