Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:12 pm
Solution
ParticipantPlease refer to the attached video to access the solution.
1. 2056788.mp4
2. 2056788.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
