August 25, 2023 at 12:16 pm
SolutionParticipantThis document is intended to familiarize existing users of Fluent with the Report Definition functionality in Release 18.0 which replaces the Solution Monitors in previous releases. Please download the attached document for complete details.
1. Using%20Report%20Definitions%20for%20Solution%20Monitoring%20in%20Fluent.pdf
