Tagged: 17.2, FLUENT Meshing/Tgrid, fluid-dynamics, mesh-quality
June 5, 2023 at 7:05 am
FAQParticipantWe can use journal files to improve the quality of a surface mesh (the quality of the mesh can be measured by the skewness). Example 1. Merge a poorly skewed surface mesh. /boundary/modify/skew /boundary/modify/merge Example 2. Smooth a poorly skewed surface mesh. /boundary/modify/skew /boundary/modify/smooth Example 3. Split a poorly skewed surface mesh. /boundary/modify/skew /boundary/modify/split
- Skewness in ANSYS Meshing
