June 6, 2022 at 8:45 am
Watch & LearnParticipantIn this video, we will see how to use interpolation functions within CFX. This can be used to create a function from a set of coordinates paired with the values of a variable at those coordinates. For example, this could be used if you wish to specify an inlet temperature using some experimentally-measured values of temperature at various points on the inlet, or if you want to specify some property of a material as a function of temperature using a table of known values.
- Skewness in ANSYS Meshing
