March 17, 2023 at 1:11 pm
SolutionParticipantIt is observed that “ELASTIC SUPPORT” can offer stiffness in only Normal direction. Spring and Joint connections are the options to leverage up on. Here a General joint based example is created and results with Beam and 3D Solid model were compared. Customer case has of 100’s of piles and interested in quick solution turnaround time. Hence an workflow of Beam model with General joint is suggested.
1. 2058795_beam_solid_model_joint_stiffness_V192.wbpz
2. Solution_ 2058795.pdf
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
