Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the solution.
1. 2054578.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
