User with mechanical license cannot create a cutcell or triangular mesh using the Assembly Meshing option in ANSYS MEshing. Why?
Tagged: 18.1, assembly-meshing, fluid-dynamics, General, meshing, Tet Meshing
June 5, 2023 at 7:06 am
FAQParticipantAssembly Meshing is using Fluent Meshing in background. After launching the meshing operation you will see a Fluent process appearing in your task manager. If there is no available Fluent-Meshing compatible license available, the meshing operation will fail with the following error message. “Error in Assembly meshing. Aborting meshing An error occurred while running the Assembly mesher. Please check the geometry or the mesh settings for problems The mesh generation was not successful.” Conclusion: You will need a Fluent Meshing license if you want to use the assembly meshing option in ANSYS Meshing.
- Skewness in ANSYS Meshing
