User getting license error as shown below: Error: ANSYS LICENSE MANAGER ERROR: Connection timed out while reading data. The application has stopped waiting for a reply. The license serve may be experiencing a high demand or a temporary outage. Try again later.
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2065448.pdf
