Upgrading to AnsysEM 2019 R2 and setting ANSYSLMD_LICENSE_FILE to point to a file containing license server information doesn’t work. It used to work in older versions of AnsysEM when using ANSOFTD_LICENSE_FILE or LM_LICENSE_FILE.
Tagged: 2019 R2, HFSS - SYS, Installation/Licensing/Systems, licensing, Other
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution. Keywords: AnsysEM
1. 2060575.pdf
