Unable to open newly installed ANSYS Workbench 17.0 Error: Unexpected Error : Exception has been thrown by the target of an invocation. System.MissingMethodException: Method not found: ‘System.Collections.Generic.IEnumerable`1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)’. at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e) at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context) at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options).
- Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)’. at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e) at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context) at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)." target="_blank" rel="nofollow" title="LinkedIn">
- Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)’. at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e) at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context) at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)." target="_blank" rel="nofollow" title="whatsapp">
- Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)’. at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e) at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context) at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)." target="_blank" rel="nofollow" title="reddit">
- Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)’. at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e) at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context) at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary`2 options)." target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 9:01 am
FAQParticipantSolution: Update Iron Python version Iron Python 2.7.4
