UDF is not working for axisymmetric model? Same UDF is working fine for planar model. Is there any limitation with Axisymmetric models.
Tagged: 19.2, Finite Rate Chemistry, fluent, fluid-dynamics, Species/Reactions, udf
January 25, 2023 at 7:17 am
FAQParticipant1. For axisymmetric models in ANSYS FLUENT are made on a 1 radian basis. When you are using certain data access macros ( for example, F_AREA or F_FLUX) for axisymmetric flows, your UDF wants to multiply the values by 2*PI( using macro M_PI) to get the desired values. 2. For axisymmetric cases, axis boundary should be aligned with Y = 0 line. 3. Please check the above conditions, UDF will work fine.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
