August 25, 2023 at 12:15 pm
SolutionParticipantThis tutorial demonstrates the turbomachinery postprocessing capabilities of CFD-Post. In this example, you will read FLUENT case and data files and perform a number of turbomachinery-specific postprocessing operations. Please refer to the attachment to access the Solution.
1. 2048143.zip
2. ANSYS%20CFD-Post%20Tutorials%20R180.pdf
- Skewness in ANSYS Meshing
