August 25, 2023 at 12:15 pm
SolutionParticipantThis tutorial illustrates how to use CFD-Post to visualize a three-dimensional turbulent fluid flow and heat transfer problem in a mixing elbow. The mixing elbow configuration is encountered in piping systems in power plants and process industries. It is often important to predict the flow field and temperature field in the area of the mixing region in order to properly design the junction. Please refer to the attachments to access the Solution.
1. 2047472.zip
2. ANSYS-CFD-Post-Tutorials_r170.pdf
- Skewness in ANSYS Meshing
