March 17, 2023 at 8:57 am
FAQ
ParticipantWhen creating a mesh with Turbo Grid, the following error message may appear. Error: ParametricCurve :: getCurve-Start and end parametric value are identical This error can occur for several reasons. One situation is if the blade leading edge is very close to or touching the inlet surface, or if the blade trailing edge is very close to or touching the exit surface.
- Skewness in ANSYS Meshing
