Tagged: 19, CFX-TurboGrid, fluid-dynamics, General, turbomachinery
April 13, 2023 at 7:32 am
SolutionParticipantThis error is generally encountered for radial impellers with splitter blades when the splitter blade is not at the high theta position. See the attached pdf to correct this problem.
1. 2056871.pdf
- Skewness in ANSYS Meshing
