June 5, 2023 at 7:05 am
FAQParticipantThe TUI has a command to improve the quality of the prism mesh. If you do the following and cannot see the effects, please take other measures such as improving the surface mesh. /mesh/prism/improve/improve-prism-cells /mesh/prism/improve/smooth-prism-cells
- Skewness in ANSYS Meshing
