Trying to create a “Bearing” connection in WB-Mechanical between two concentric surfaces. It remains underdefined (?) after scoping the Reference and Mobile surfaces. What would cause this?
January 25, 2023 at 7:34 am
FAQParticipant“Bearing” Connection option only works when scoped to geometry entities that are perfectly concentric. After scoping the Reference and Mobile bodies, carefully check the X,Y,Z coordinates reported in the details window of the Bearing connection. They need to be exactly the same. If they are even slightly different, due perhaps to geometric tolerance issues, the Bearing will remain underdefined. This can be corrected by copying the coordinates from Reference body to Mobile body or visa-versa. This is only a valid fix if the difference in coordinate values is negligeibly small. Check results carefully.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
