April 5, 2023 at 2:33 pm
FAQParticipantConfirm the Version of OFED ofed_info | head This command will check to see if the device state is “Active” or not? Determining if OFED services are running Open a terminal window and type: which ibstat Once located cd to the directory if not in your path and type: ibstat To Display the Local Host’s IB Device Status Use these commands to test your Infiniband status and send the output to support Ibstat ibv_devinfo ibstatus Restarting Infiniband /etc/init.d/openibd restart List All IB Hosts in the IB Network ibhosts To test if the modules are installed type: /sbin/lsmod | grep rdma
