Tagged: 17.2, FLUENT Meshing/Tgrid, fluent-meshing, fluid-dynamics, mesh-quality
June 5, 2023 at 7:05 am
FAQParticipantWhen selecting Skewness on the Report Quality Measure panel, you can select the Tri/Tet Skewness Method. The two options are as follows: Equilateral Volume Deviation: Calculated based on the inscribed circle of the cell (only valid for triangles and tetrahedrons) Normalized Equiangle Deviation: Calculated based on the angle of the cell (valid for all cells i.e. pyramids, prisms, etc.)
- Skewness in ANSYS Meshing
