Tagged: 19.1, mechanical, structural-and-thermal, structural-mechanics, thermal, transient
April 5, 2023 at 2:32 pm
FAQParticipantPlease note that the Steady State Thermal results are not time bound and they show the final state of the body after thermal equilibrium conditions. Where as for Transient Thermal, we need to consider time as well to settle the bodies with respect to heat transfer. If the Transient Thermal results – for example Temperature is increasing or decreasing at the end time, it indicates there is still heat transfer happening and we may need to increase the end time.
