June 5, 2023 at 7:05 am
FAQParticipantWhen wrapping, the use can either do one of two things: make the initial mesh rough and then refine it, or make the initial mesh fine and roughen it. If you create rough meshes and make them finer, you will get a resolution that deviates from the original shape. If you first create a fine mesh and then roughen with Post Improve, then you can generate the desired mesh. By setting the Default Length to half of the initial value and setting the min length to 4 to 5, it is possible to generate a surface mesh close to the original shape.
- Skewness in ANSYS Meshing
