June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video introduces basic steps required to determine the maximum temperature and stress achieved by a component due to thermal load using ANSYS AIM Student. For questions or to learn more visit http://www.ansys.com/studentcommunity
