June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video introduces basic steps required to find out the maximum temperature achieved by component due to thermal load. From the beginning to 7.10, you will understand the process of carrying out steady-state thermal analysis on a component. From 7.10 to the end, you will learn the process of transferring thermal load on the mechanical side using Workbench coupling to find out stress and deformation. Learn more at http://www.ansys.com/studentcommunity
