March 17, 2023 at 9:00 am
FAQParticipantMPC-based contact can be used initially, and after a solve (or even PSOLVE,ELFORM), issue CELIST,,,,CONV. This will convert the internal constraint equations created by the contact elements into external constraint equations. Then you can delete the contact elements.
