January 13, 2026 at 7:35 am
Watch & LearnParticipantIn a structural-thermal simulation, you can choose how to define the conductive heat transfer between contact surfaces. This video explains how you can do that in Discovery 2026R1.
Important considerations:
If contact occurs, a small value of thermal contact conductance yields a measured amount of imperfect contact and a temperature discontinuity across the contact surfaces. A small thermal contact conductance can also be used to represent a thin layer of material with a different conductivity, such as a gasket.
For large values of thermal contact conductance, the resulting temperature discontinuity tends to vanish and perfect thermal contact is approached. With a zero value, however, the solver assumes that no heat is transferred across the contacting surfaces.
Note: While the application can solve with a value of 0, which specifies no electric transfer between the faces, a project with a 0 value for electric conductance is invalid when exported to the Workbench application. You must then replace zero conductance with some small value.
