May 5, 2024 at 11:11 am
SolutionParticipantIn this article we will learn how Ansys Discovery can be used to perform thermal analysis of a heat sink placed above two CPUs generating heat during intense computational tasks.
Please refer the attached document for steps to perform thermal simulation in Ansys Discovery. We will see how use of heat sinks guarantees thermal safety of CPUs in electronic devices.
Download the Simulation files from here to follow the steps in the document.
Refer Design Scenarios for thermal safety of CPUs article where we will explore the impact of material, geometry, and heat sink operating environment to lower the temperature of the CPUs.
Using Parametric Analysis in Heat sink with two CPUs using Ansys Discovery we will learn how changing the flow speed influences lowering the temperature of CPUs for intense computations.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
- Thermal Analysis of Heat Sinks with Ansys Discovery
