April 5, 2023 at 2:32 pm
FAQParticipantThere are two possible explainations: 1. User has a 3DSpace Ball installed with an unsupported graphics driver. Refer to Installation and Licensing Docs for latest supported hardware. 2. Problem with User Profile. Try Deleting and recreating User Profile.
