Tagged: 2019 R1, mechanical, static, structural-and-thermal, structural-mechanics, thermal
March 17, 2023 at 1:11 pm
SolutionParticipantKeywords: Trace Mapping Theory Please download attached paper.
1. Electronic PCB and PKG Thermal Stress Analysis.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
