The units of my geometry will not be imported correctly, if I import my Gambit geometry (*.dbs) in ANSYS DesignModeler, why?
April 5, 2023 at 2:33 pm
FAQParticipantGambit geometries are created w/o any unit information. When DM imported the geometry from .dbs (gambit) it assumes that the unit is mm. This is set by default and cannot be changed by the user. To fix the issue with the incorrect size of your model in DesignModeler, you can scale your geometry in DesignModeler by using “Create” -> “Body Transformation” -> “Scale”.
- Skewness in ANSYS Meshing
