Tagged: 17.2, FLUENT Meshing/Tgrid, fluid-dynamics, General
June 5, 2023 at 7:05 am
FAQParticipantIf you do not know the meaning of a TUI command, enter “?” followed by the unknown command. If you only enter “?”, it will launch help mode. To exit help mode, enter “q”. Example 1 Find the meaning of the “display” command. >?dis display/: Enter the display menu. ← The meaning of the display will be shown. Example 2 Find the meaning of “annotation text”. > display/annotate Annotation text [“”]? Enter the text to annotate the plot with. ← The meaning of annotation text will be displayed.
- Skewness in ANSYS Meshing
