The reactor network model available in Fluent is used to simulate species and temperature fields in a combustor using a detailed chemical kinetic mechanism. In V19.0, while displaying contours of Reactor Network parameters such as reactor net zone ID or temperature, below error message pops up in Fluent console Error at Node 0: Different species order in mechanism vs Fluent case: re-import chemkin mechanism Error at host: Different species order in mechanism vs Fluent case: re-import chemkin mechanism Error: Different species order in mechanism vs Fluent case: re-import chemkin mechanism Error Object: #f Error: Invalid result name. Error Object: ()
Tagged: 19, Finite Rate Chemistry, fluent, fluid-dynamics, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantCurrent workaround is to execute the following command in the FLUENT console window before post-processing for the reactor-network model: (%kinetics-finish)
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
