March 17, 2023 at 9:00 am
FAQParticipantSome other (non-ANSYS) software installation may put older version Intel Compiler dynamic link library (e.g. 2017) files under C:Windowssystem32, Instead of renaming C:Windowssystem32libmdd.dll (2017) , we moved libmdd.dll (2019) from ANSYS *v212tpIntelCompiler2019.3.203winx64libmdd.dll to fluent location. both solutions are to use libmdd.dll 2019 version.
