The pre-mesh quality check for determinants indicates negative determinants, but when highlighting the histogram bars below zero they do not appear inverted.
Tagged: 14.5, fluid-dynamics, General, Hexa, icem-cfd
March 17, 2023 at 8:58 am
FAQParticipantThis is because the block itself has a left-handed orientation. If you select additional negative determinant histogram bars, they will appear to fill an entire block. The left-handed blocks occur from bottom-up operations such as creating blocks, merging vertices and entire topologies, and copying blocks. They are easily made into right handed blocks by using “Blocking [tab]>Block Checks>Fix Inverted Blocks.” These can also be fixed by writing an unstructured mesh and using “Edit Mesh [tab]>Check Mesh>Volume orientations.” When it finds orientation problems, choose the automatic “fix.”
- Skewness in ANSYS Meshing
