The pdf table generated by FLUENT requests the user to enter the number of points in fvar and cvar. What is the maximum value of fvar and cvar? Are the fvar and cvar points equally spaced?
Tagged: 17.2, Eddy Dissipation, fluent, fluid-dynamics, Species/Reactions
June 5, 2023 at 7:05 am
FAQParticipantThe Max. values for both cvar and fvar are 0.25. This is hardwired and there is no option to change this. The grid points are not equally distributed. Both grids are refined near the value of 0.0, using a power law.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
