The following command works in R16 but not in R17. file export f-u filename () * () velocity () Are there any changes in R17?
Tagged: 17, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantThe issue is with Fieldview. It is been resolved using following rpvar. Please use following rpvar. (rpsetvar ‘export/fieldview/serial? #t)
- Skewness in ANSYS Meshing
