The error of libQt5Core.so.5 When the following error occurred, this issue relates QT library. Stack backtrace generated for process id 12680 on signal 11 : 1000000: fluent() [0x67f3b9] 1000000: /lib64/libc.so.6(+0x32510) [0x2aaab2990510] 1000000:
March 17, 2023 at 9:01 am
FAQParticipant/ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN31QAbstractEventDispatcherPrivate15allocateTimerIdEv+0x40) [0x2aaaaf9beed0] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN24QAbstractEventDispatcher13registerTimerEiN2Qt9TimerTypeEP7QObject+0x19) [0x2aaaaf9bf4e9] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN7QObject10startTimerEiN2Qt9TimerTypeE+0x5e) [0x2aaaaf9efd4e] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN6QTimer5startEv+0x3c) [0x2aaaaf9fadec] 1000000: fluent(_ZN5CxGui12setBusyStateE11CxBusyState+0x53) [0x7d3303] 1000000: fluent(CX_Primitive_Error+0x187) [0x67dcc7] 1000000: fluent() [0x67f430] 1000000: /lib64/libc.so.6(+0x32510) [0x2aaab2990510] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN31QAbstractEventDispatcherPrivate15allocateTimerIdEv+0x40) [0x2aaaaf9beed0] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN24QAbstractEventDispatcher13registerTimerEiN2Qt9TimerTypeEP7QObject+0x19) [0x2aaaaf9bf4e9] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN7QObject10startTimerEiN2Qt9TimerTypeE+0x5e) [0x2aaaaf9efd4e] 1000000: /ansys_inc/v192/fluent/lib/lnamd64/Qt/lib/libQt5Core.so.5(_ZN6QTimer5startEv+0x3c) [0x2aaaaf9fadec] 1000000: fluent(_ZN5CxGui12setBusyStateE11CxBusyState+0x53) [0x7d3303] Please include this information with any bug report you file on this issue! ============================================================================== In R19.2, FLUENT has been migrated from QT4.8 version to QT5.10 version. QT5.10 has some issues related to XCB on Linux platform specially with x11. You need to install the following libraries. xcb-util-image-0.4.0-3.el6.x86_64 xcb-util-keysyms-0.4.0-1.el6.x86_64 xcb-util-wm-0.4.1-5.el6.x86_64.
