The customer has only one license for Professional NLS. ANSWAIT is set so that the remote solve should start once the license is freed. When he tries to solve remotely, the process ends without waiting until the license is available. Why is it not working as expected?
April 13, 2023 at 7:32 am
SolutionParticipantThere is a problem in WB 11.0 sp1 where the ability to select the Professional NLS license for the remote solve is not enabled. This is to be fixed in WB 12.0. If the customer wants to always use the Professional NLS license for solving and is solving to a Windows machine, the attached AnsysUtils.cs file will allow this to work. In the folder [RSMInstall]/Config/scripts/, rename AnsysUtils.cs to AnsysUtilsorig.cs and use the attached AnsysUtils.cs file in its place.
1. 739796.zip
