The customer can use Ansys Motion and all related toolkits in the standalone version of Motion. But inside Workbench Mechanical he can use the Motion anaysis system but the toolkits are greyed out in the Motion ribbon of Mechanical and can not be used.
Tagged: ANSYS Motion, General, Installation/Licensing/Systems, N/A
March 17, 2023 at 9:00 am
FAQParticipantInstall the License Manager on the client. There is no need for a license file or for it to be running. It uses some of the licensing tool exe files and the Motion icons are greyed out if these files are missing. It is also resolved in 2021R2
