Surface coatings are not being transferred over when I make an assembly model. Is there something I need to do to transfer the surface coatings?
March 17, 2023 at 9:00 am
FAQ
ParticipantThis is a limitation in Mechanical. Enhancement request has been submitted to include this feature in future release. Here is supported objects that can be transferred in model assembly. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/wb_sim/ds_mech_model_import.html For now, you have to create surface coating in the assembled model
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How to use ANSYS Workbench for Merging Mesh Nodes
- How can you identify the element types used by Mechanical?
