Tagged: 18, cfx, fluid-dynamics, General - CFX, multiple-bodies, name selections
June 5, 2023 at 7:05 am
FAQParticipantWhen multiple bodies are present, and more than one body is visible in Meshing when named selections are created, the resulting named selection may contain faces from multiple bodies. This will prevent the named selections from showing up in the list of region for a domain that contains just a single body. The “best practice” approach in this case is to only have one body visible at a time when selecting faces for a named selection.
- Skewness in ANSYS Meshing
