March 2, 2022 at 4:10 am
Watch & LearnParticipantThis video introduces basic steps required to solve the FEA problem using ANSYS Static Structural. From the beginning to 4:50, you will learn how to import geometry, apply materials & use multizone method to generate the quality mesh. From 4:50 to the end, you will learn to apply BCs and post-process the results to find out maximum stress and deformation. Learn more at http://www.ansys.com/studentcommunity
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
