Tagged: 19.1, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantThe following suggestions can help with this: 1. Change the contact formulation to MPC contact instead of program controlled. 2. Change the mesh density between the 2 contacting parts and get it to be as close as possible.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
