June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video designed with FSAE and BAJA student teams in mind, you will learn how to apply forces, generate coordinate system and use adaptive meshing techinques to understand stress and deformation. For questions and support, join the Ansys Student Community: https://studentcommunity.ansys.com/
